Foldarap2: underplate mirrored
Posted by nachetz
April 28, 2014 03:36AM
Hi again!!
i'm founding quite a lot problems with the foldarap building manual:
if I install the lasercut underplate as said on the manual the power supply is not aligned to the Y stepper (photo attached) ....
It seems as the underplate was mirrored and i must turn it 180º and leave the Openedge logo inside the foldarap
anyone else with this problem??
open | download - IMG_20140428_091355.jpg (227.5 KB)
Re: Foldarap2: underplate mirrored
April 28, 2014 09:24AM
Bonjour,
Are you following the right instructions ? I found that the right ones are here
It looks to me as if you can just turn the whole thing round by 180° (but with the OPenedge logo still underneath) : then the mains power terminals will be in front of the power switch, and the power supply will be on the correct side.
Glenn
Edited 1 time(s). Last edit at 04/28/2014 09:26AM by Glenn81.
April 28, 2014 12:09PM
Have a look at the electronic board chapter. It looks like your pic : [reprap.org] cool smiley
For mine, I made it little different (for wiring acces). Have a look to the last pic here : [www.thingiverse.com] (the one with the wiring) winking smiley
regards
April 28, 2014 01:33PM
Great!!
thanks for the link, great secuence of the process... really useful!!
i think i'm going to do as you and move the power suplly for wiring acces
thanks again!
mattsi
regards
April 28, 2014 01:34PM
Thore are instructions for Foldarap 1, am i wrong?
Glenn81
Bonjour,
Glenn
April 29, 2014 07:53AM
Hi Mattsi!!
did it work to you wiring endstops on NC instead of NO? i see on bluilding manual photos both options...
Regards!
mattsi
regards
April 29, 2014 01:00PM
Haven't try the NO wiring yet (and i will try NC after if it doesn't work). winking smiley
I have sent a PM to Emmanuel, to have his advice.
April 29, 2014 01:45PM
Little update : the config COM and NO blocks the move in X-; Y-; Z- (even if you use pin + instead of pin - on the electronic board).
I'll have to change that.
