X & Y axis problems
Posted by nachetz
X & Y axis problems
May 03, 2014 12:52PM
Hi!!
finally y wired everything and uploaded the Marlin Foldarap2 Minitronic firmware.
Everything seemed to be ok till y moved X axis and Y axis backwards: both motors got blocked... I mean: if i move along X axis it goes well in one direction but when i try to move the motor backward it gets blocked, a really strange noise begins and the temperature of the nema increases a lot!!
The same happens to Y axis....
Both motors seem not to stop... i have to stop them via Repetier Host, Pronterface...
Someone with the same issue??
Edited 1 time(s). Last edit at 05/03/2014 12:59PM by nachetz.
Re: X & Y axis problems
May 03, 2014 01:04PM
Do you verify voltage on minitronics ?
And how do you connect endstop ?
May 03, 2014 01:14PM
I connected endstops as Emmanuel said on the recent endstops update...
I did not verify voltage... Z axis works perfect, and X & Y in one direction...
May 03, 2014 01:32PM
You were right!! too much voltage on X&Y....
i think its solved!
al44
