3D Printer Suggestions for a Beginner
Posted by markyoe
August 03, 2015 05:04PM
I have been researching about building a 3D printer but have not yet decided on which model to build. Are there any RepRap printer designs with detailed instructions that you guys would suggest? Thank you!
Re: 3D Printer Suggestions for a Beginner
August 04, 2015 01:57AM
I would suggest the Prusa i3. There is a wealth of information about it, and, as it was the first (and only) printer I built, I can assure you it wasn't particularly challenging (but challenge adds to the fun, right?). You can find information regarding the Prusa i3 here. There is even a convenient kit offered by the designer, in case you don't want to spend time sourcing parts. Mine uses a box frame with a direct drive extruder, found here. I wish you good luck in your printer-building journey!
Edited 1 time(s). Last edit at 08/04/2015 01:58AM by marikokur.
August 04, 2015 02:05AM
Thanks for the response! What do you think about this kit? [www.3dprintersonlinestore.com] I have been in contact with one of the product specialists. He gave me links to the instructions:
Assembly Video: [www.youtube.com]
User manual: [drive.google.com]
Good buy or no?
August 04, 2015 02:13AM
Yeah, no problem! The price looks good, as do the reviews; however, I am unfortunately not the most experienced person in the 3D printing game, so take my answer with a grain of salt. Still, from the looks of it, I would say it's a good buy. I suggest you hold off for a bit, though, and look online some more for other offers. Who knows--maybe you'll find the printer somewhere else for cheaper.
August 04, 2015 02:31AM
Ok. I have seen the same one on ebay for about $10 cheaper but this website had pretty good customer service. Folger Tech is probably just the brand name or style of the Prusa i3 right?
August 04, 2015 02:35AM
I believe it is just the brand name, but as the Prusa i3 is an open source design, there are probably a number of minute differences specific to this design. This shouldn't be an issue, though, because you have assembly instructions specific to this model provided by the manufacturer.
August 08, 2015 03:52AM
I am trying to decide between two printers. One printer can print down to .1mm layer thickness and one can print down to .05mm. Will I need the .05mm thickness or will the .1mm thickness prints look good?
August 08, 2015 05:03AM
In my experience, .1 mm is plenty. In fact, I generally print at around .2 mm, which I find to be good enough. Anything under that seems like a bit of a waste of time (as these prints will be substantially longer) and materials.
August 08, 2015 11:40AM
What material is your frame made of? I am trying to decide between an aluminum Folger Tech and a Sunhokey acrylic with a few freebies.
August 08, 2015 02:47PM
My frame is made from pine. However, if you would be willing to go down that route, I would suggest using MDF, as it is easier to laser cut.
August 08, 2015 05:47PM
Another printer that I found is the Printrbot Play. From a review I watched, it is a pretty good printer at a decent price ($399). You can get it either pre-assembled or as a kit. Here's a link to the website, if you're interested.
August 08, 2015 08:34PM
Thanks for the recommendation. I think this one looks pretty good. [www.3dprintersonlinestore.com] tech It seems to be an upgrade from the acrylic frame Folger Tech. Do you think I need to know a lot about software to run and calibrate this? I have downloaded Repetier-Host.
