Ribbon cable wires for extruder?
Posted by mmt
mmt
August 21, 2012 03:03PM
I've got 28 AWG ribbon cable, 26,20 & 10 way. Here's data spec:
Ribbon cable
The cable looks flimsy. I can see putting 10 wires together ok for the bed heater, but is 2 wires together for the extruder heater still looks flimsy. I'm thinking use 26 way cable with 5 wires per heater line.
Any thoughts, any one done anything like that?
Re: Ribbon cable wires for extruder?
August 21, 2012 04:08PM
If 10 wires are good for a 10A bed then 2 must be good for 2A. IIRC they are rated for something like 1.4A per wire. I expect there is some de-rating for wires together, but a ribbon must much better than a bundle in that respect. Also the insulation is rated for 105C so they can even run hot.
I haven't had any problems with 2 for the heater although the new design I am working on I have used a 15 way D type to allow the use of a IDC, so I increased to 3 for the heater. That will allow for heaters with 2 resistors which some people have moved to.
mmt
August 22, 2012 02:23AM
Ok, got it, thanks.
acc
August 27, 2012 02:27AM
I've used 3 wires for both +12v and gnd, each of them AWG 28. I used 26-way ribbon cable, so I still have two free lines (one maybe for the cooler, and one extra). I heated the nozzle and the cables were not warm at all.
However if I did it again, I would use 4 wires. This is because Sanguinololu has 2 pins for both +12v and gnd, so I had to split one wire of 3. Now my connection to Sanguinololu has 1.5 wire to each pin. Using 4 wires will be easier to assemble - 2 wires per each pin
Here's how I dealt with it:
- from sanguinololu there are 4 pins, I connected 2 ribbon wires to each of them, so total 8 - very short ones, a few cm
- I've soldered together left 4 and right 4, so these are +12v and gnd respectively
- from the other side I've soldered together each 3 of them (these ones going to extruder heater)
- and now connected joined fours with joined threes :-)
Edited 1 time(s). Last edit at 08/28/2012 01:09AM by acc.
