Hello,
for a LED lamp I'm developing, I printed a test object, to try out, what are the design limitations regarding overhang and bridges (attached pictures).
The object is printed with ABS at 230° extruder and 120° bed temperature over PET tape. It has a large 45° overhang. At the beginning of printing the fan was switched off, resulting in some problems (circle 1 in the pictures). I switched on the fan and the overhang was stabilized.
Bridges up to 20mm came out with a only small (in this case acceptable) slack.
I'm not shure if these are the limits, which I can expect, or there are settings in Skeinforge for further improvements.
Another problem, I discovered, is a gap between layers (circle 2 in picture 2), probably by some thermal strain during printing. Is there a way to avoid this?
Generally I'm looking for a way to improve the layer adhesion, to avoid heavy structures at the arm of the LED lamp.
