Does anyone have .1mm layer height settings for Skeinforge? I've been messing with it the past few days and can't seem to figure out the flow rate setting or the ratio of edge width over height. I've improved from each change I make, but I can't get rid of large blobs (this is my first attempt at printing a very small part).
In the attached image, the piece on the right was my first attempt, and the piece on the left is my latest attempt. The blobs on top of the two central columns have improved, but they're still not perfect.
The blob seems to be from the nozzle sitting too long in that small area and causing the plastic to melt, or it may be extruding too much plastic. To attempt to remedy this, I have multiplied the print (from 1 to 4) and dropped my extruding temp from 215 to 200. This has helped, but I'm still not getting the best results. Without multiplying more (as I only want 1 piece), is there another way of adding cool time? Or any other suggestions to improve this print?
