You have already learned that
Base layers (integer): and
Interface layers (integer): both need to be
0 to disable generation of the raft.
The
Interface Infill Density (ratio): controls the density of the support material. The default value of
1.0 is probably too high for your needs.
The
Support Gap over Perimeter Extrusion Width (ratio): defines the gap between the printed object and the support material. For a perimeter line width of 0.5mm, a value of 4.0 would give a gap of 2mm.
The
Support Material Choice: setting lets you choose where to place support material e.g. Exterior Only, Empty Layers Only or Everywhere.
I cannot see any method of limiting the number of support layers. If you are providing support underneath an overhang then Skeinforge should calculate the number of layers for you. In your application, assuming you are printing your case open-side down, then setting the Support Material Choice to Empty Layers might be appropriate to support the interior of the case. I would guess that Infill Density should be as low as possible to ease removal e.g. 0.2 (or 20%). As for Support Gap over Perimeter Extrusion Width, this too would be quite small, maybe 1.0 or less.
EDIT: Corrected Support Flow Rate over Operating Flow Rate (ratio): to Interface Infill Density (ratio): and added some suggested values.
Regards,
Neil Darlow
Edited 1 time(s). Last edit at 02/23/2014 11:29AM by neildarlow.
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
