Finished building the Mendel90.
What works:
- Extruder and bed heating
- Thermistors
- x axis movement
- x axis homing
What doesn't work:
- Only one motor on the z axis moves, the other one is unpowered. I can move it manually without resistance
- z axis and y axis are swapped. Moving the printer up and down moves it back and forward
- y axis alignment doesn't work, the switch gets pressed but it doesnt stop. Probably related to the swapped axis.
Using windows8 and the default settings from the reprap firmware (baud @ 250000)
Edited 2 time(s). Last edit at 02/23/2014 11:43PM by Diemex.
