Polypropylene sheet sourcing in the USA January 25, 2014 03:20PM |
Re: Polypropylene sheet sourcing in the USA January 25, 2014 06:23PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Polypropylene sheet sourcing in the USA January 26, 2014 09:50AM |
Re: Polypropylene sheet sourcing in the USA January 26, 2014 03:23PM |
Re: Polypropylene sheet sourcing in the USA January 26, 2014 05:19PM |
Re: Polypropylene sheet sourcing in the USA January 26, 2014 10:10PM |
nophead
The purpose is to enforce a minimum bend radius on the wire like cable chains do on larger machines. Without them the wire would just bend at ends and soon wear out.
Re: Polypropylene sheet sourcing in the USA January 27, 2014 05:42AM |
Re: Polypropylene sheet sourcing in the USA January 27, 2014 11:02AM |
Re: Polypropylene sheet sourcing in the USA January 27, 2014 11:45AM |
Re: Polypropylene sheet sourcing in the USA January 27, 2014 03:55PM |
Re: Polypropylene sheet sourcing in the USA January 27, 2014 07:36PM |
cdru
When I was looking for something suitable, I found the thin sheets used as cutting mats perfect, they bend pretty easily but keep a decent radius while also supporting the ribbon. Should be able to find one pretty cheap at most stores that sell housewares.
Re: Polypropylene sheet sourcing in the USA January 28, 2014 01:06AM |
Re: Polypropylene sheet sourcing in the USA January 28, 2014 08:48AM |
It doesn't HAVE to be polypropylene. Anything that's flexible but still maintains a decent bend radius will work. Other things that I've thought of is the metal or plastic strapping that is used to hold large boxes together, items to pallets, or stacks of lumber. Any lumber yard likely has ample amounts of scrap that they would just give you.Quote
unicoder
I think I just found another good alternative. I took a look at the bottom of a large tub of Smart Balance (margarine) and next to the recycle symbol it has a PP. I assume that stands for polypropylene? I cut it apart and found that I could get strips up to around 420 mm around the circumference. It's quite flexible and the thickness is around 0.54 mm. Too bad it's still not long enough for using MDF12. I need 477 mm. I'm wracking my brain now to try to come up with a food product or other product that comes in plastic contains with a larger diameter. I might have to look over some bulk-size containers next time I'm at the supermarket
Re: Polypropylene sheet sourcing in the USA January 29, 2014 11:17AM |
Re: Polypropylene sheet sourcing in the USA April 03, 2014 08:05AM |
Re: Polypropylene sheet sourcing in the USA April 03, 2014 08:51AM |
Re: Polypropylene sheet sourcing in the USA April 03, 2014 04:04PM |
Re: Polypropylene sheet sourcing in the USA April 04, 2014 10:10PM |
Re: Polypropylene sheet sourcing in the USA January 26, 2016 12:45AM |
Re: Polypropylene sheet sourcing in the USA January 26, 2016 06:46PM |
