M10 threaded rod not possible
Posted by acc
acc
November 15, 2012 07:55AM
I tried to generate x-ends for 12mm smooths rod and 10mm threaded rod. However, x-ends do not scale this way, so there is no place to put walls around M10 nut holder in x-ends. Also, it goes out too much and influences LM12UU holders.
Nophead, any plans to update the scripts to make it possible ?
Re: M10 threaded rod not possible
November 15, 2012 09:05AM
You absolutely don't want to use threaded rod that thick - you get reduced steps/mm (probably not a problem though) but also you'll get lots of fighting since the threaded rod is so strong. Go for m8, or even m5.
acc
November 16, 2012 03:55AM
I have M8 already, but I'd like to switch to trapezoidal one - 10x2 as 8mm trapezoidal spindles are very hard to get...
September 05, 2013 01:26PM
hi
any news for this?
greetings smuk3d
September 05, 2013 02:36PM
Sorry I don't have time to do custom design work for people.
The reason it doesn't work is because the Z rods stand 50% on the edge of the motors. That isn't possible if you have massive Z bars and lead screws but not correspondingly bigger motors. The Z motor bracket design would need to change.
September 06, 2013 05:05AM
ok, thanks ...
than i try M8 at first .. thanks for answer :-)
best regards from germany
Smuk3D
