Skeinforge missing extruder amounts from G1 lines?
Posted by Jonny1983
April 13, 2013 05:13PM
I've been playing with the Mendel90 today getting it to print out the Android well. Now I'm looking at slicing some stls from Thingiverse using Skeinforge that came on the SD Nophead packs with the kit.
However I'm having problems with it, and looking at the generated gcode I can see the G1 lines don't have any extruder amounts in it. I've copied across the config as per Nopheads instructions so most of the tabs should have config from it.
Anyone know why this is? Skeinforge is setup for PLA Extrusion.
Below is a sample from the start of the code
M83
G28
G1X5Y98F9000
G1Z0.05
M104 S200
M190 S60
M109 S220
G92 E0
G1E2F50
G1E-1.5F1200
G1X40F4000
G1Z0.3
G90
G21
M103
M106
M140 S60.0
M141 S30.0
M142 S0.0
M113 S1.0
M108 S84.0
G1 X-18.72 Y-17.608 Z0.1 F60.0
M101
G1 X-17.593 Y-18.734 Z0.1 F384.0
G1 X-16.382 Y-19.802 Z0.1 F384.0
G1 X-15.106 Y-20.792 Z0.1 F384.0
G1 X-13.771 Y-21.699 Z0.1 F384.0
G1 X-12.381 Y-22.521 Z0.1 F384.0
G1 X-10.943 Y-23.254 Z0.1 F384.0
G1 X-9.461 Y-23.895 Z0.1 F384.0
G1 X-7.942 Y-24.442 Z0.1 F384.0
G1 X-6.391 Y-24.892 Z0.1 F384.0
G1 X-4.816 Y-25.245 Z0.1 F384.0
Edited 1 time(s). Last edit at 04/13/2013 05:14PM by Jonny1983.
open | download - Skeinforge Screenshot.jpg (168.3 KB)
Re: Skeinforge missing extruder amounts from G1 lines?
April 13, 2013 06:23PM
It won't produce E values if the Dimension module is not activated but the config I distribute does have it set.
Copy the config to the correct place and don't change any settings and it will work. Leave the profile set to ABS. The only difference between PLA and ABS is the temperatures and as that is defined in the start.gcode file I didn't change the profile from ABS. It's a bit confusing I know, but I have no time to sort it out at the moment.
April 13, 2013 07:15PM
Cheers Nophead, gcode looks to be working great now.
November 02, 2013 01:59PM
Thanks this resolves my issue too. I will close out my other thread smiling smiley
