Issues again with my Mendel90
Posted by Anonymous User
Anonymous User
April 22, 2013 08:47AM
hi,
i have new Problems with my Mendel90 printer.
i made no changes .. it just apeared.
take look:
[i.imgur.com]
[i.imgur.com]
i triyed changing diameter and temperature and no changes.
no matter wich layerhigh0 how fast, always same problems every few layers.
i hope somebody can help.
greetings
Re: Issues again with my Mendel90
April 22, 2013 10:01AM
Looks like something wrong with the Z axis. The bands look to be once per rev of the lead screw and get worse as the part gets taller.
Is the object the correct height or a bit short? Perhaps Z is missing steps once per rev. Do the pointers stay in step?
Anonymous User
April 22, 2013 10:24AM
the object is 0.04mm to short. i think this its ok.
what i can do to fix that.
here a small video of the rods while turning, hopefully helps
[www.vidup.de]
April 22, 2013 11:32AM
Perhaps put oil on the leadscrews, reduce the speed or the acceleration.
Are you using the same firmware settings as provided? I.e. same Z speed and acceleration and not disabled when not moving.
Anonymous User
April 23, 2013 12:17AM
Hello nophead,
i use now the original config.h from you. Just changed e-step and Home_Z and still have same issues.
i tryed another calibratio n part, and again waves in the corners.
Anonymous User
April 23, 2013 03:42PM
i tryed to print without headbed and this issue is almost gone.
Is there a way to get a more constant heatflow with mendel90 ?
regards
April 23, 2013 05:23PM
Not sure what you mean. Are you saying the bed is flexing causing the horizontal banding? Seems odd it as looks to be every 1.25mm.
Anonymous User
April 26, 2013 01:57PM
i played all over my printer. the effect is little less now, dont know why.
my next problem is skipping stepps.
i have now a aluminiumplate on the m2 heater (4mm) + a thin printsheet and woll under the heatplate for more isolation.
I believe my bed is to heavy now sad smiley.
is it possible and what can i do ?
regards
Edited 1 time(s). Last edit at 04/26/2013 01:59PM by Repper.
April 27, 2013 09:50AM
Reduce the acceleration in the firmware. Try 2000 or maybe 1000.
Anonymous User
April 27, 2013 09:47PM
i reduced acceleration to 1000.
perimeter 30
infill and spare 50
still skipping steps .
no luck sad smiley
April 28, 2013 04:04AM
How heavy is the bed?
f = ma so if m is say three times bigger use 2000 / 3.
Check the bed is moving freely when the belt is removed. Perhaps it is binding for some reason.
