NOOB needing help on first build
Posted by qwert75
May 03, 2013 10:20PM
hello, basicly ive just completed the kit supplied by nophead and wired it all up, everything works except the x axis stepper, when you try and jog it it vibrates and makes alot of noise and doesnt go anywhere.
As this is my first time i really dont want to go messing around with things before i get a bit of advise.
does anyone have any ideas as to what could be causing the issue.
im using pronterface to jog ten as the manual says.
all other motors wired up the same work perfectly.
Re: NOOB needing help on first build
May 03, 2013 10:38PM
What does an M119 command in pronterface return? This will help us see if it is end stop related.
Have you verified the color of the stepper wires, through the flat cable, and into the Melzi?
Fl0yd
May 03, 2013 10:44PM
very sorry my mistake, i have been building very tired, looks like it connected the incorrect ribbon cable to the incorrect colour, guess thats what you get from revising for exams =']
thankyou fl0yd for replying but its sorted
