Download and install OpenSCAD from here: [
www.openscad.org]
Download the Mendel90 files from github using the "download as zip" button here: [
github.com]
Unzip them, run openscad and use the file open menu option to navigate to where you put the files and open the main.scad in the scad directory.
Press F5 and wait for it to render. You can then pan, rotate and zoom the 3D view with the mouse.
You don't have to worry about Python and make_machine if you only want to view the Dibond version as conf\machine.scad now defaults to that.
You can look at sub-assemblies by opening the corresponding scad files. To get an exploded view edit scad\conf\config.scad and changed exploded to 1.
Edited 2 time(s). Last edit at 06/27/2013 05:34PM by nophead.
www.hydraraptor.blogspot.com]
