Help! Filament jammed! July 19, 2013 04:31AM |
Re: Help! Filament jammed! July 19, 2013 05:22AM |
Re: Help! Filament jammed! July 19, 2013 06:50AM |
Re: Help! Filament jammed! July 19, 2013 07:04AM |
Re: Help! Filament jammed! July 19, 2013 07:22AM |
Admin Registered: 19 years ago Posts: 7,883 |
After cranking up the E temp to 210
Re: Help! Filament jammed! July 19, 2013 07:43AM |
What temperature were you extruding at?
) that it can happen when my E temp is too high, causing the filament to "drip" as it travels from tower to tower.
Re: Help! Filament jammed! July 19, 2013 10:31AM |
Re: Help! Filament jammed! July 19, 2013 11:58AM |
Re: Help! Filament jammed! July 19, 2013 01:02PM |
Re: Help! Filament jammed! July 19, 2013 01:30PM |
Re: Help! Filament jammed! July 19, 2013 01:58PM |
Re: Help! Filament jammed! July 19, 2013 02:53PM |
and made a clip (which I need to redesign as it is too loose really) which attaches it to the X carriage - pointing towards the top of the JHead. The fan is wired to permanent 12V on the extruder PCB. Fingers crossed but this has worked without problems for months. I keep the fan which Chris supplied with the kit permanently fixed for both PLA and ABS and I can get top quality prints from both materials. I will try and post a photograph later this weekend if I get the chance.|
Re: Help! Filament jammed! July 19, 2013 07:27PM |
Re: Help! Filament jammed! July 19, 2013 08:02PM |
Re: Help! Filament jammed! July 20, 2013 04:29AM |
Re: Help! Filament jammed! July 20, 2013 08:34AM |
Re: Help! Filament jammed! July 20, 2013 01:48PM |
Re: Help! Filament jammed! July 21, 2013 07:27AM |
Re: Help! Filament jammed! July 21, 2013 09:30AM |
Re: Help! Filament jammed! July 21, 2013 09:41AM |
Re: Help! Filament jammed! July 21, 2013 11:30AM |
Re: Help! Filament jammed! July 21, 2013 01:38PM |
Re: Help! Filament jammed! August 09, 2013 02:48PM |
If I notice it soon enough I can retract the filament, cut off the "buckle" and put the filament back in. If i don't notice it gets that big than I wether can't extract or retract anymore and I have to take the extruder apart.|
Re: Help! Filament jammed! August 09, 2013 05:28PM |
Re: Help! Filament jammed! August 09, 2013 07:12PM |
Re: Help! Filament jammed! August 11, 2013 04:35AM |
Re: Help! Filament jammed! August 11, 2013 05:55AM |
Re: Help! Filament jammed! August 11, 2013 12:34PM |
Yamster
Just curious, what is the temperature setting that you have settled at and was able to print without jamming with? You are still using PLA, right?
Re: Help! Filament jammed! August 11, 2013 03:42PM |
Re: Help! Filament jammed! April 25, 2015 11:20AM |
