modifications
August 08, 2013 02:04PM
I had a few modifications in mind, but don't have the knowledge to calculate whether or not they'd have any side effects, so I thought I'd post them here and see what you guys/gals think.
1: Aluminum extruder assembly:
My wade's block has a small crack in it and I don't think it's because of overtightening, because I can't loosen it anymore without it running into the x motor assembly. So I figured maybe it'd be better to make the entire extruder assembly (not the carriage/fan duct/d connector) out of aluminum so that it'd be able to withstand more heat and pressure as well as longer life for the gears. My questions are would the increase in weight require a larger x motor and would the larger x motor then require larger z motors?
2: Aluminum bar/motor supports:
Printing at any appreciable speed causes a lot of vibration ( I can hear it all the way across the house) so I was wondering if it'd be worth making all the supports out of aluminum as well to make all the moving parts more stable. I know it'll be an improvement, but I just don't know if it'll be significant. Any opinions on this?
3: Insulated build chamber:
Has anyone done this with a mendel 90? And if I did end up doing this, what would be the optimal temperature? Would the heated bed need to be on anymore?
Thanks for any input.
Re: modifications
August 10, 2013 03:13PM
The Wade's block on a machine I have printing 24/7 since the first batch of kits has a few cracks stress cracks behind the bearings but it still prints fine. They do eventually wear out, especially if run in a heated chamber but since I started printing them at 95% infill I think they have all outlasted their hot ends so I have never have to replace one.
I think the Y axis weighs more than X, so until you make X heaver it will have little effect. Beyond that you will need to reduce the acceleration or use a bigger motor. If you use a bigger motor you might need different electronics to get much benefit. You might also want a wider belt.
The Z motors will be able to lift a lot more weight due to the mechanical advantage of the lead screws.
Not sure if aluminium sheets would be louder or quieter. The PE core in the Dibond probably dampens the sound. My guess is solid aluminium would ring but it is hard to say because it depends on resonant frequencies, etc.
> anymore?
I run my Sturdy90 in an MDF box. It runs at 45C, which is about the max temperature for the ABS brackets because the extruder motor gets up to about 65C. The heated bed is still required.
The ideal chamber temperature for ABS is about 70C but then you can't make the machine from ABS brackets. At that temperature you might not need a heated bed but you then probably have to use rafts as commercial machines do.
Re: modifications
August 12, 2013 02:19AM
ok thanks, definitely gives me a better perspective. About the infill of the wades block, is that the only one you print at a different infill? Or do you print each piece at different infill ratios and types?
And one more thing I'd like to get your opinion on is the steel rods. It looks like most of the weight of the x carriage comes from the motors and the steel rods. Would it be possible to replace the steel rods with carbon fiber tubes and still get the same amount of stability?
Re: modifications
August 12, 2013 05:41AM
I use different infill type, ratios and layer heights for different parts.
The x carriage runs on steel rods, they don't add to its weight. They do add to the weight the Z axis has to lift but that moves very slowly so isn't an issue. The rods are h6 tolerance, hardened, ground steel rods to match the specification for the LM8UU bearings. I don't think carbon fibre rods would have the tolerance or the hardness required.
Re: modifications
August 12, 2013 12:27PM
Are the different slicing settings available anywhere online? If not would you be willing to share them? I understand if you're not.
Re: modifications
August 12, 2013 12:54PM
BrianC
Yup! smiling smiley
[reprap.org]
Re: modifications
August 12, 2013 01:03PM
Are they in the github repository? I just did a quick scan over the master file but I didn't see anything...I might have just missed it though.
Re: modifications
August 12, 2013 02:21PM
They're on the reprap wiki - click the link in my above post! smiling bouncing smiley
Re: modifications
August 12, 2013 03:25PM
Ohh, sorry for some reason I thought that was a signature lol. Thanks!
