You will need to slide rods through a clamp, a bearing and into another clamp. The whole rod must be grease-free for the first clamp but you could just degrease the far-end after passing the bearing but before entering the second clamp.
I just degreased the whole rod and lubricated after final assembly.
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
