Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 13, 2013 05:28PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 13, 2013 05:37PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 13, 2013 05:56PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 13, 2013 05:57PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 13, 2013 06:24PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 13, 2013 06:30PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 13, 2013 06:42PM |
Nilez
Makes sense indeed, so no amount of oil will ever fix that then.
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 13, 2013 08:10PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 14, 2013 01:08AM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 14, 2013 02:33AM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 14, 2013 01:23PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 14, 2013 02:59PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 14, 2013 05:17PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 16, 2013 02:46PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 16, 2013 08:37PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 17, 2013 02:05AM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod November 19, 2013 08:21AM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod December 05, 2013 07:15PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod December 06, 2013 02:53AM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod December 06, 2013 12:11PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod December 07, 2013 11:53AM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod December 07, 2013 04:29PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod December 07, 2013 07:13PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod December 07, 2013 08:34PM |
Re: Squealing/squeaking and Ticking from Right Hand Z Threaded Rod December 09, 2013 11:17AM |
[SOLVED] Squealing/squeaking and Ticking from Right Hand Z Threaded Rod January 10, 2014 02:18AM |
nophead
I think the Z bars must be slightly out of alignment so all the weight is taken by the left end and the right nut has no pressure on it. That allows the screw to rattle against it with the vibration from the motor.
Maybe loosening the screws on the Z bar clamps and the Z motor brackets would allow the bars to lean to the right a little to allow the motor end to drop onto the nut.
