Duff Stepper Motor?
November 23, 2013 01:58PM
Evening all,
I powered up my '90 for the first time today and found that everything worked fine apart from one of the Z Motors. One side would work fine the other wouldnt move at all. Checked all the wiring and it was correct, so disconnected both motors and just wired the non-moving one into the board. When I tried to move it in the Ponterface software the motor just lets out a high pitched beep. Its also locked solid - i cant turn the shaft by hand like the others.
Is there anything I can do or is the motor seized up and I need a new one?
Thanks, Andrew
Re: Duff Stepper Motor?
November 23, 2013 05:21PM
You can try loosening the screws and re-centering the end caps to see if you can free it. If the motor has been dropped they can get offset such the rotor touches the stator.
November 26, 2013 04:39PM
Hi, I tried that but its still locked solid. I'll send you an email later to arrange purcahsing a replacement.
November 29, 2013 03:14AM
Incidentally, how long can we expect the steppers to last?
It it prudent to have a spare on hand or will the printers be obsolete by the time it comes to need a replacement?
November 29, 2013 04:52AM
I have never known one to fail. When a machine comes to the end of its life I recycle the motors in the next one.
I think the only thing that wears is the bearings and as they are ball bearings, and don't actually spin very fast, they last a very long time. You could actually replace them if needed as they are a standard size 5mm bearing.
