Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 02:15AM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 02:28AM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 03:34AM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 04:17AM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 07:04AM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 03:10PM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 03:13PM |
QuackingPlums
I have my bed preheat and ooze-free gcode incorporated into my slicer's start code and I usually have plenty of time between the bed reaching temperature and the nozzle coming down to meet the bed to remove my cardboard blanket.
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 03:43PM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 25, 2013 04:00PM |
BrianC
I use a 1/2" sheet of foam insulation board under the heated bed. I think another benefit of insulating is increased efficiency, because you lose less heat from the underside of the bed.
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 26, 2013 05:33AM |
; ***** Ooze-free start with wipe ***** G90 ; Set positioning to absolute G21 ; Set units to millimeters G28 ; Home all axes G92 E0 ; Reset extruder M42 S255 P28 ; Turn on the gantry LEDs on FET 1 G1 Z200 X-45 Y95 F12000 ; Move above block point M190 S[first_layer_bed_temperature] ; Pre-heat the bed & wait as it takes 10mins M117 Remove blanket! M104 S[first_layer_temperature] ; Start heating the extruder before lowering the nozzle G1 Z0.1 X-45 Y95 F12000 ; Lower to block point and block nozzle M109 S[first_layer_temperature] ; Wait for extruder to reach first layer temperature M117 Starting in: 30 G4 S5 ; Wait another 30 seconds for nozzle length to stabilise M117 Starting in: 25 G4 S5 M117 Starting in: 20 G4 S5 M117 Starting in: 15 G4 S5 M117 Starting in: 10 G4 S1 M117 Starting in: 9 G4 S1 M117 Starting in: 8 G4 S1 M117 Starting in: 7 G4 S1 M117 Starting in: 6 G4 S1 M117 Starting in: 5 G4 S1 M117 Starting in: 4 G4 S1 M117 Starting in: 3 G4 S1 M117 Starting in: 2 G4 S1 M117 Starting in: 1 G4 S1 G1 E3 ; Extrude 3 mm of filament G1 X45 Y95 F12000 ; Wipe nozzle across the bed G1 Z1 ; Raise nozzle to 1 mm ready to begin main sequence G92 E0 ; Reset extruder M201 X2000 Y2000 ; max acceleration in X and Y M117 Printing...
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 26, 2013 07:05AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 26, 2013 07:27AM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 26, 2013 09:34PM |
Anonymous User
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 30, 2013 10:24AM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 30, 2013 01:10PM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 30, 2013 01:36PM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? November 30, 2013 01:51PM |
Anonymous User
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? December 02, 2013 09:01AM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? December 02, 2013 12:32PM |
Ralph Hilton
Garry - the site has a button near the top to get it in English. It does look similar, yes.
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? December 02, 2013 04:55PM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? December 06, 2013 01:13PM |
; ***** Ooze-free start with wipe ***** ; ***** Original author QuackingPlumbs ***** ; ***** Mangled by Garry Bartsch ***** G90 ; Set positioning to absolute G21 ; Set units to millimeters G28 ; Home all axes G92 E0 ; Reset extruder G1 Z200 X-45 Y95 F12000 ; Move above block point M190 S[first_layer_bed_temperature] ; Pre-heat the bed & wait as it takes 10mins M104 S[first_layer_temperature] ; Start heating the extruder before lowering the nozzle G1 Z0.1 X-45 Y95 F12000 ; Lower to block point and block nozzle M109 S[first_layer_temperature] ; Wait for extruder to reach first layer temperature G4 S30 ; Wait another 30 seconds for nozzle length to stabilise G1 E3 ; Extrude 3 mm of filament G1 X45 Y95 F12000 ; Wipe nozzle across the bed G1 Z1 ; Raise nozzle to 1 mm ready to begin main sequence G92 E0 ; Reset extruder M201 X2000 Y2000 ; max acceleration in X and Y
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? December 06, 2013 01:30PM |
Re: Alternatives to Cardboard Heat Barrier Under The Heated Bed? December 09, 2013 10:01AM |
M190 S[first_layer_bed_temperature] - 5didn't work for me. Maybe I have the wrong syntax.
