Marlin RAMPS 1.4 Mendel90 January 20, 2014 03:52PM |
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. //#define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS // Disable max endstops for compatibility with endstop checking routine #if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS) #define DISABLE_MAX_ENDSTOPS #endif // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR 1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 100 #define X_MIN_POS -100 #define Y_MAX_POS 100 #define Y_MIN_POS -100 #define Z_MAX_POS 170 //This is just an initial setting so I don't crash the head. THIS WILL NEED TO BE ADJUSTED. #define Z_MIN_POS 0 #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
Re: Marlin RAMPS 1.4 Mendel90 January 20, 2014 06:29PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Marlin RAMPS 1.4 Mendel90 January 21, 2014 02:43AM |
Re: Marlin RAMPS 1.4 Mendel90 January 21, 2014 03:55PM |
Re: Marlin RAMPS 1.4 Mendel90 January 21, 2014 05:17PM |
Re: Marlin RAMPS 1.4 Mendel90 January 21, 2014 05:34PM |
Re: Marlin RAMPS 1.4 Mendel90 January 21, 2014 09:53PM |
Re: Marlin RAMPS 1.4 Mendel90 January 21, 2014 10:15PM |
Re: Marlin RAMPS 1.4 Mendel90 January 21, 2014 11:38PM |
Re: Marlin RAMPS 1.4 Mendel90 January 22, 2014 06:03AM |
I was deliberately vague in my explanation because merging nophead's changes into current Marlin is not entirely trivial and if you do attempt it then you should be prepared to investigate how settings are handled by the code.Quote
Miterez1
neildarlow, is this why you're referring to: #define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used.
If I am supposed to use MANUAL_HOME_POSITIONS, any little bit of guidance would be appreciated.
Re: Marlin RAMPS 1.4 Mendel90 January 26, 2014 03:00AM |
Re: Marlin RAMPS 1.4 Mendel90 February 04, 2014 04:46PM |
