Absolutely wierd banding - Help please! February 14, 2014 03:33PM |
Re: Absolutely wierd banding - Help please! February 14, 2014 05:39PM |
Re: Absolutely wierd banding - Help please! February 15, 2014 01:50AM |
Re: Absolutely wierd banding - Help please! February 15, 2014 05:02AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Absolutely wierd banding - Help please! February 15, 2014 10:08AM |
Re: Absolutely wierd banding - Help please! February 15, 2014 05:46PM |
Re: Absolutely wierd banding - Help please! February 16, 2014 06:53AM |
Re: Absolutely wierd banding - Help please! February 16, 2014 01:36PM |
Re: Absolutely wierd banding - Help please! February 16, 2014 01:39PM |
Re: Absolutely wierd banding - Help please! February 16, 2014 03:23PM |
nophead
If the bands are closer together at the bottom because the bottom layers are bigger, what causes them to get closer again further up the columns?
Re: Absolutely wierd banding - Help please! February 16, 2014 06:10PM |
Re: Absolutely wierd banding - Help please! February 17, 2014 07:01AM |
Re: Absolutely wierd banding - Help please! February 18, 2014 03:52AM |
Re: Absolutely wierd banding - Help please! February 18, 2014 11:43AM |
Re: Absolutely wierd banding - Help please! February 18, 2014 04:11PM |
Sorry what tracks?Quote
nophead
Is it mounted with the tracks on the bottom?
214x202 ( 202 - Y dimension)Quote
nophead
Do you have glass the same size as the BOM?
clips as in PDFQuote
nophead
Do you have the glass and clips positioned and oriented as the model shows?
Re: Absolutely wierd banding - Help please! February 18, 2014 06:34PM |
Re: Absolutely wierd banding - Help please! February 19, 2014 02:33AM |
Re: Absolutely wierd banding - Help please! February 19, 2014 04:47AM |
Re: Absolutely wierd banding - Help please! February 19, 2014 06:22AM |
Re: Absolutely wierd banding - Help please! February 19, 2014 06:28AM |
neildarlow
There has been a video posted on YouTube recently showing heated bed PCB flexing on a Mendel90. It looks like the poster was getting 0.05mm of flex at 70C with bang-bang heating. I have asked if he can re-test with PID and post his results.
Re: Absolutely wierd banding - Help please! February 19, 2014 07:27AM |
It's not enough.Quote
probonic
I had a very similar problem to you. Here are things to try:
- Make sure there are no drafts in the vicinity of the printer
- Try putting the clips as close to the edges/corners as you possibly can
- Make sure you always have the corrugated cardboard under the bed
After doing all these things I got really good prints.
Re: Absolutely wierd banding - Help please! February 19, 2014 08:21AM |
When using bang-bang you will always get some movement - the only thing you can do is minimise the effect. The suggestions I mentioned for me greatly reduced the movement of the build plate. Everyone's mileage will vary.Quote
karabas
It's not enough.
See video bang bang
When on(click 0:07) - you see light in gap between caliper and X smooth rod
When off (click 0:23)- no gap.
As I understand - when on, bed becomes lower.
Re: Absolutely wierd banding - Help please! Solved. February 20, 2014 05:08PM |
