"Uneven" Printing Bed Handeling
Posted by sguzzel
February 21, 2014 09:05AM
Hallo,
I took the time last evening to calibrate my printing bed. That was when I discovered it isn't really even, the border is about 0,1mm higher than the middle. It looks now exactley like this:
(not really scaled, and in bracets are the difference from the zero level in 0,01mm)
|+10|..............|+10|..............|+10|
|+00|..............|+00|..............|+00|
|+10|..............|+07|..............|+10|
For the square from mendel90s x=y: -40....+40 it looks like this (koordinates|difference from zero point)
[40,-40|+1]..[20,-40|+1]..[0,-40|+1]..[-20,-40|+2]..[-40,-40|+2]
[40,-20|-1]..[20,-20|-1]..[0,-20|-1]..[-20,-20|+0]..[-40,-20|+0]
[40,00|-2]..[20,00|-2]..[0,00|0]..[-20,00|-1]..[-40,00|+0]
[40,20|-2]..[20,20|-2]..[0,20|-1]..[-20,20|-1]..[-40,20|+0]
[40,40|0]..[20,40|0]..[0,40|0]..[-20,40|0]..[-40,40|+1]
Under the Printing bed I have no cardbord, instead I use this [www.electronic-things.de] (should be stone wool). Rest of the printer is as nophead sold it to me, i only bought 13mm maulys instead of the 19mm, which tendend to crash into the frame.
My concerns are now:
- How to calibrate the printer: Use the mainly used zero point and adjust first layer height for bigger prints? How shure can I be that the noozle doesn't crash in the glass bed at the heigher border?
- How can I fix the uneven bed? Even without the glass and only the mk2 bed i have the same issue
Re: "Uneven" Printing Bed Handeling
February 21, 2014 11:41AM
The PCB will not in general be anywhere near flat. The idea is the glass forms the flat surface. People often report the middle lower but in actual fact the spring of a dial gauge is enough to bend it.
