Re: Updated Marlin customized for Mendel90 May 26, 2014 03:13PM |
bastard
Neil - is it possible to merge his changes into yours?
Re: Updated Marlin customized for Mendel90 July 01, 2014 06:06AM |
Re: Updated Marlin customized for Mendel90 July 01, 2014 07:59AM |
Re: Updated Marlin customized for Mendel90 July 01, 2014 09:33AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Updated Marlin customized for Mendel90 July 01, 2014 10:07AM |
nophead
It isn't possible for the thermistor to become detached when it is stuck in with cement. The only way to get it out is by drilling it. If the wires become detached you get a MIN_TEMP error. If they are shorted you get MAX_TEMP. A partial short causes the hot end to run cool.
In the event of the heater being permanently on due to a failed MOSFET or a firmware bug I don't think it will start a fire because the limited power of 25W only produces about 300C. The problem is caused by 40W heater cartridges that will get to ridiculous temperatures in the event of a fault and thermistors fastened in with kapton tape or silicone sealant.
The bed temperature is self limiting due to the resistance of copper increasing with temperature.
Re: Updated Marlin customized for Mendel90 July 02, 2014 11:07AM |
Re: Updated Marlin customized for Mendel90 July 02, 2014 11:08AM |
Re: Updated Marlin customized for Mendel90 July 02, 2014 03:43PM |
Re: Updated Marlin customized for Mendel90 August 25, 2014 12:01AM |
Re: Updated Marlin customized for Mendel90 August 25, 2014 08:45AM |
Re: Updated Marlin customized for Mendel90 August 27, 2014 05:03PM |
Re: Updated Marlin customized for Mendel90 August 28, 2014 10:54PM |
Re: Updated Marlin customized for Mendel90 August 29, 2014 12:21PM |
LCD_CLASS lcd(LCD_I2C_ADDRESS,LCD_I2C_PIN_EN,LCD_I2C_PIN_RW,LCD_I2C_PIN_RS,LCD_I2C_PIN_D4,LCD_I2C_PIN_D5,LCD_I2C_PIN_D6,LCD_I2C_PIN_D7);
Re: Updated Marlin customized for Mendel90 September 02, 2014 12:34PM |
Re: Updated Marlin customized for Mendel90 September 04, 2014 08:18AM |
Re: Updated Marlin customized for Mendel90 September 05, 2014 02:57PM |
neildarlow
@goopyplastic: Have you enabled the Thermal Runaway Protection feature? I can see a possible scenario where it might trigger and halt your printer without notice.
The default settings for the Heated Bed Thermal Runaway Protection have just 2 degrees hysteresis and with normal on-off temperature control this may not be sufficient.
I do not enable this feature by default although I have it enabled on my printer but I use PID temperature control for the heated bed.
Regards,
Neil Darlow
Re: Updated Marlin customized for Mendel90 September 06, 2014 09:36AM |
Re: Updated Marlin customized for Mendel90 October 13, 2014 09:56PM |
Re: Updated Marlin customized for Mendel90 October 14, 2014 04:05AM |
Re: Updated Marlin customized for Mendel90 October 14, 2014 04:30AM |
Re: Updated Marlin customized for Mendel90 October 14, 2014 04:37AM |
Re: Updated Marlin customized for Mendel90 October 14, 2014 04:48AM |
Re: Updated Marlin customized for Mendel90 October 14, 2014 04:54AM |
Re: Updated Marlin customized for Mendel90 October 14, 2014 05:23AM |
Re: Updated Marlin customized for Mendel90 October 14, 2014 08:19PM |
Re: Updated Marlin customized for Mendel90 October 15, 2014 02:35AM |
Re: Updated Marlin customized for Mendel90 October 15, 2014 04:14AM |
Re: Updated Marlin customized for Mendel90 October 15, 2014 05:29AM |
Re: Updated Marlin customized for Mendel90 October 15, 2014 08:18AM |
Re: Updated Marlin customized for Mendel90 October 15, 2014 10:08AM |
atmega1284.build.variant=standardThis too should be available if the installation procedure has been followed correctly.
