Re: Updated Marlin customized for Mendel90 October 15, 2014 11:17AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Updated Marlin customized for Mendel90 October 15, 2014 08:35PM |
Re: Updated Marlin customized for Mendel90 October 16, 2014 04:20AM |
C:\Users\Neil\My Documents\Arduino C:\Users\Neil\My Documents\Arduino\hardware C:\Users\Neil\My Documents\Arduino\hardware\Melzi C:\Users\Neil\My Documents\Arduino\libraries C:\Users\Neil\My Documents\Arduino\libraries\LiquidTWI2 C:\Users\Neil\My Documents\Arduino\MarlinThe file I open in the Arduino IDE is C:\Users\Neil\My Documents\Arduino\Marlin\Marlin.ino
Re: Updated Marlin customized for Mendel90 October 16, 2014 04:53AM |
Re: Updated Marlin customized for Mendel90 October 16, 2014 06:47PM |
Re: Updated Marlin customized for Mendel90 October 17, 2014 03:02AM |
Re: Updated Marlin customized for Mendel90 January 04, 2015 09:14AM |
neildarlow
@sguzzel: The 203mm was the original Z_HOME_POS setting in Nophead's Marlin. The Z_MAX_POS was calculated as (Z_HOME_POS - 0.1).
In my firmware the Z_HEIGHT_MM is used to set MANUAL_Z_HOME_POS when MANUAL_HOME_POSITIONS is defined or Z_HOME_POS when MANUAL_HOME_POSITIONS is not defined.
In either case, Z_MAX_POS is set to 200 and will be consistent for all printers (Nophead's would vary the Z_MAX_POS depending on the calibrated Z_HOME_POS of the printer).
I have Z_HEIGHT_MM at 203.0 simply as a place-holder. You should replace this value with your calibrated Z Height value as described in the Build Manual.
Regards,
Neil Darlow
Re: Updated Marlin customized for Mendel90 January 21, 2015 04:43AM |
Re: Updated Marlin customized for Mendel90 January 21, 2015 08:18AM |
Re: Updated Marlin customized for Mendel90 January 21, 2015 08:53AM |
Re: Updated Marlin customized for Mendel90 January 21, 2015 09:02AM |
Re: Updated Marlin customized for Mendel90 January 21, 2015 09:23AM |
Re: Updated Marlin customized for Mendel90 January 21, 2015 11:24AM |
Re: Updated Marlin customized for Mendel90 January 21, 2015 01:57PM |
Re: Updated Marlin customized for Mendel90 January 22, 2015 06:29AM |
Re: Updated Marlin customized for Mendel90 February 02, 2015 08:15PM |
Re: Updated Marlin customized for Mendel90 February 03, 2015 02:51AM |
Re: Updated Marlin customized for Mendel90 February 03, 2015 08:26AM |
Re: Updated Marlin customized for Mendel90 February 03, 2015 08:43AM |
#define LCD_I2C_PANELOLU2Regards,
Re: Updated Marlin customized for Mendel90 February 03, 2015 08:48PM |
Re: Updated Marlin customized for Mendel90 February 04, 2015 05:15AM |
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_X_POINT 0 //(X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_Y_POINT 0 //(Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
Re: Updated Marlin customized for Mendel90 February 04, 2015 05:19AM |
Re: Updated Marlin customized for Mendel90 February 04, 2015 05:33PM |
Jesse_Blue
Open Configuration.h and search for
#ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
change it into
#ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT 0 //(X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT 0 //(Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
compile and upload then try G28 again.
Re: Updated Marlin customized for Mendel90 March 20, 2015 06:49PM |
Re: Updated Marlin customized for Mendel90 March 21, 2015 07:19AM |
Re: Updated Marlin customized for Mendel90 March 21, 2015 08:34AM |
Re: Updated Marlin customized for Mendel90 March 21, 2015 03:07PM |
Re: Updated Marlin customized for Mendel90 March 21, 2015 04:34PM |
Re: Updated Marlin customized for Mendel90 March 21, 2015 05:46PM |
