Re: Fumes? March 20, 2014 01:24PM |
Re: Fumes? March 20, 2014 05:18PM |
Re: Fumes? March 26, 2014 05:15AM |
Re: Fumes? March 26, 2014 08:12AM |
Re: Fumes? March 26, 2014 11:20AM |
Re: Fumes? March 26, 2014 12:09PM |
Re: Fumes? January 30, 2015 12:41PM |
Re: Fumes? February 13, 2015 04:58AM |
neildarlow
The only thoughts I have are that the hot-end fan will push the fumes down towards the heated bed and they will circulate everywhere from there. I think it might be an idea to vent the case at the centre-rear and let clean air in at the top of the case. A low airflow should prevent too much breeze effect and the incoming cool air will mix with any rising warmer air. I am not sure that the conventional wisdom of pulling the air out of the case top is a good idea when you consider the machine structure and existing forced airflow.
Regards,
Neil Darlow
