Hi All,
I'd like to use a seperate sheet of glass to print ABS from the one I use for PLA.
The glass I got from a customer of mine is thicker than the original stuff by about .3mm
U use Pronterface/Slicer a bit but more and more these days I'm using Cura V14.
Is there any way to offset the Z0 height in the software? (both)
I could recompile the FW but it seems like quite a faff just to swap between materials.
I was sure I'd seen a setting somewhere in Cura to set up a Z offset but i'm damned if I can find it now?
Anyone any ideas or am I stuck modding the FW each time?
Cheers
D
