Have you searched your GCode for M106?
On the
Cool tab of Skeinforge, make sure
Activate Cool is ticked and the following set (as a guide):
Full Fan Speed (0-255): 255
Do Not Use Fan Before Layer (integer): 1
Force Fan on Bridge Layers: Ticked
Maximum Layer Time for Fan Use (seconds): 239.0
Full Fan Speed Below Layer Time (seconds): 239.0
I think there was a syntax error in the original cooling patch that referred to
Below as
Bellow but that is of no consequence functionally.
That should be all you need.
Regards,
Neil Darlow
Edited 1 time(s). Last edit at 05/10/2014 06:46AM by neildarlow.
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
