Quick question about heater cartridge wiring.
Posted by jakobnator
May 14, 2014 11:25PM
Hello, I am almost done with M90 and I am trying to put the heater cartridge wires in the screw in terminals on the x carriage. However, the wire is 16 awg and it looks like the terminals are meant for ribbon cable size wire. I was going to peel back 3/4 the thickness of the wire but it looks messy and then it starts to touch the other heater wire. Is there a better way to do this? All the pictures I see online seem to be that the wire fits in the terminal perfectly.
Re: Quick question about heater cartridge wiring.
May 15, 2014 05:19AM
Cartridge heaters used for reprap don't normally have 16 AWG wires. What power rating is it?
May 15, 2014 08:05AM
It's a cheap one I got from eBay, I am assuming that its 16 awg just because of the heat resistant wire.
According to the ebay page:
resistance of resistor 4.7Ω
resistor rated power 8W
Edited 1 time(s). Last edit at 05/15/2014 08:05AM by jakobnator.
May 15, 2014 10:34AM
Maybe off topic given that the following has nothing to do with the wire gauge but.....
If you connect 4.7R to a +12V supply, you will draw 2.55A of current and generate 30.6W of power.
Using a 6V supply, you draw 1.28A and generate 7.6W which is close to what the figures suggest. All I am saying is take care and make sure that you only operate the cartridge when fitted into the hot end heater block and that you have good thermal contact.
Alan
