Switching to ABS - need any tips or tricks May 28, 2014 09:06AM |
Re: Switching to ABS - need any tips or tricks May 28, 2014 10:15AM |
lions3
This week i've starting to use ABS now that I have a E3D v5 extruder.
Re: Switching to ABS - need any tips or tricks May 28, 2014 10:35AM |
Re: Switching to ABS - need any tips or tricks May 28, 2014 03:43PM |
130c for the bed? Wow. A co-worker had a solidoodle and I remember he was running at 110. So I just assuming I would probably need to run something similar.Quote
Bed needs to be around 130C
Thanks for reminding me. I completely forgot to update it the firmware for E steps.Quote
May need to recalibrate your E steps per mm
As to the fumes. How long do they linger? Do they settle if I put the printer in a box?Quote
The problem is you kind of need to have better ventilation of your room to stop your self being (slightly) poisoned by the ABS
Re: Switching to ABS - need any tips or tricks May 28, 2014 05:00PM |
Re: Switching to ABS - need any tips or tricks May 28, 2014 05:20PM |
. I am sharing my details and lets hope you find them useful!|
Re: Switching to ABS - need any tips or tricks May 28, 2014 07:06PM |
Re: Switching to ABS - need any tips or tricks May 29, 2014 02:05AM |
Re: Switching to ABS - need any tips or tricks May 29, 2014 08:03AM |
Re: Switching to ABS - need any tips or tricks June 02, 2014 10:05AM |
Re: Switching to ABS - need any tips or tricks June 02, 2014 11:00AM |
Re: Switching to ABS - need any tips or tricks June 02, 2014 11:24AM |
Re: Switching to ABS - need any tips or tricks June 02, 2014 11:46AM |
Re: Switching to ABS - need any tips or tricks June 02, 2014 09:19PM |
Re: Switching to ABS - need any tips or tricks June 03, 2014 03:54AM |
Re: Switching to ABS - need any tips or tricks June 03, 2014 06:03AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Switching to ABS - need any tips or tricks June 03, 2014 07:53AM |
Re: Switching to ABS - need any tips or tricks June 03, 2014 10:32AM |
Re: Switching to ABS - need any tips or tricks June 03, 2014 11:07AM |
Re: Switching to ABS - need any tips or tricks June 03, 2014 11:10AM |
Re: Switching to ABS - need any tips or tricks June 03, 2014 11:38AM |
Re: Switching to ABS - need any tips or tricks June 03, 2014 02:12PM |
Re: Switching to ABS - need any tips or tricks June 03, 2014 04:42PM |
Re: Switching to ABS - need any tips or tricks June 04, 2014 02:38PM |
QuackingPlums
Hmm.Now I have even more questions! Have any of these been answered already?:
Does a heated chamber at, say 45C reduce the temperature gradient across the bed? i.e. would it be easier to hit 110C at the corners if the ambient temperature within the enclosure was higher?
QuackingPlums
If I could somehow ensure the bed stayed above Tg for the first layer, would the temperature gradient for subsequent layers be less of an issue? Is there any reason why the firmware restricts the bed temperature to a maximum of 135C?
QuackingPlums
Is there a thermally conductive material we could use (such as thin alu sheet with suitable thermal transfer paste/adhesive that isn't electrically conductive) to spread the heat on the Prusa bed more evenly?
QuackingPlums
Is there a better alternative to the Prusa bed that will run off the 12V ATX supply? I know people have mentioned CF mats and other alternatives but none that sounded like a satisfactory drop-in replacement IIRC.
QuackingPlums
Is the problem strictly related to bed-temperature, air temperature, proximity to other parts/baffles or a combination? I'd be happy to reserve the outermost 5mm of the bed for printing a baffle (and thus reduce my maximum printable area to, say 190mm x 190mm) if this would be sure to eliminate all lifting issues for example. Likewise I would invest the time and effort into building a PID-controlled heated chamber if there is a "magic" temperature that would cure this issue.
QuackingPlums
One thing I noticed when I was trying to work out optimum temperatures is that dropping the bed temperature to <120C for subsequent layers resulted in lifting even for small (50mm x 50mm) parts. This was measured temperature at the edges of my parts on top of the glass, not by the thermistor.
If for whatever reason the Tg is higher on my ABS then I doubt I'd stand a chance of ever getting the corners of my bed that hot.
Re: Switching to ABS - need any tips or tricks June 07, 2014 08:24AM |
Re: Switching to ABS - need any tips or tricks June 07, 2014 09:11AM |
Re: Switching to ABS - need any tips or tricks June 07, 2014 09:42AM |
Re: Switching to ABS - need any tips or tricks June 11, 2014 01:39PM |
Re: Switching to ABS - need any tips or tricks June 11, 2014 10:43PM |
Re: Switching to ABS - need any tips or tricks June 12, 2014 07:37AM |
