Problem printing Mendel90 Parts
June 22, 2014 12:41PM
my Mendel90 had a crack on the extruder. So i decided to print a new one. Afaik i´ve read somewhere in a post from Nophead, that the Mendel90-Parts are designed to be printed with a Layerheight of 0.4. So i used a 0.6mm Nozzle and printed the extruder Parts with a layer height of 0.4. When the print was finished, i noticed that the printed parts have small gaps when there are Holes near the perimeter of the object, or at the edges of the Object. (See attached Pics).
The parts were sliced in Skeinforge using the following settings:
Edge Width over Height: 1.5
Layer Height: 0.4
Perimeter Flow Rate Multiplier: 0.857
It seems that Skeinforge calculates the width of the outlines too big. Where the holes are near the outline, there are only 2 lines used to cover a gap of about 2mm (see attached Pic). Is there any parameter in Skeinforge which could be causing this problem besides Edge Width over Height?
open | download - IMG_20140617_155120.jpg (310.7 KB)
open | download - IMG_20140617_155202.jpg (271.2 KB)
open | download - Unbenannt.JPG (155.3 KB)
Re: Problem printing Mendel90 Parts
June 22, 2014 04:25PM
I print everything with a single outline. Looks like you have two outlines.
June 22, 2014 07:12PM
Also I use a 0.45mm nozzle for 0.4 layers, not 0.6mm. I think that is why your extrusions are tending to round off sharp corners leaving the small gaps at the sides.
The large gaps at the end are due to there not being enough room for double outlines. Skeinforge fails to put infill in gaps between outlines. It only fills inside the inner outlines.
June 22, 2014 08:56PM
How can i print with a single outline? I haven´t found any parameter in Skeinforge to configure the number of outlines.
Edited 1 time(s). Last edit at 06/22/2014 08:56PM by Xerius.
June 23, 2014 03:06AM
On the Fill tab change the values under - Extra Shells - to zero. This will print only one shell for each case.
Regards,
Neil Darlow
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
