Top surface quality issue eye rolling smiley
Posted by Mytch
June 28, 2014 11:19AM
Hi everyone!
It's been a year or so since I have my Mendel90 and I printed many stuff in PLA/ABS/Ninjaflex without any really big issue. It's really a nice printer.
I'm using Skeinforge and change the parameter by fallowing the advince in the manual of the M90, however, I have a little problem with the quality of the final layer surface.
I don't have this issue when I print with a 0,3mm or 0,2mm layer height, but with a 0,25mm, W/H ratio of 2,08, perimeter flow rate of 0.896826 and nozzle of 0,4mm.
The material is natural ABS printed at 265°C.
Here the link of the photo:
[mytch.free.fr]
The little part of the T is alright, but the infill of the long part is quite spaced.
(The bits of plastics at the bottom is due to the brim)
Do you have any ideo of what parameter might help?
Thanks!
Mendel90 from Nophead + E3D v5
Smartrap from Smartfriendz
Re: Top surface quality issue eye rolling smiley
June 29, 2014 06:34AM
Your image does not show the infill clearly enough. I can just see steps due to the slope of the long element but not infill detail.
Regards,
Neil Darlow
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
June 29, 2014 07:28AM
Haha, thanks Neil!
It look like the real issue is with my brain eye popping smiley
Indeed, I was talking about the steps...obiously caused by the slope…
Sorry, guess I need some sleep...
June 29, 2014 09:45AM
have you tried slicing it in Cura or Slic3r?
Drag the gcode into pronterface and you can see how it will print.
June 29, 2014 02:50PM
I didn't visualize the g-code before…my bad, but indeed, by looking at the slice in Cura or even with skeinlayer, it look like it printed like it should have.
It was a mistake on my part,
