X Axis 8mm Brass Nut July 11, 2014 09:49PM |
Re: X Axis 8mm Brass Nut July 12, 2014 02:42PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: X Axis 8mm Brass Nut July 13, 2014 12:00AM |
Re: X Axis 8mm Brass Nut July 13, 2014 04:30AM |
nophead
The nut fits in the top of the end. The hole at the bottom is 1mm bigger to allow it to pass through easily.
The nut trap for the lead screw is now at the top (don't be fooled by the hexagonal hole at the bottom, that is just clearance to allow the nut to be fitted to the leadscrew first). This greatly increases the distance of the nut from the Z coupling when the Z axis is at the bottom. When the nut was at the bottom it got to within about 10mm so any eccentricity was magnified by about 20 at the top of the leadscrew.
Because holes can't be printed in mid air there are one layer thick support membranes at the bottom and the top of the nut trap. This creates a completely enclosed void which revealed a bug in OpenScad. It generates an STL with the internal faces facing the wrong way, i.e. outwards instead of inwards. Fortunately Skeinforge does not care and slices it correctly but Slic3r doesn't.
Re: X Axis 8mm Brass Nut July 13, 2014 08:52PM |
Re: X Axis 8mm Brass Nut July 14, 2014 07:28AM |
Re: X Axis 8mm Brass Nut July 14, 2014 07:35AM |
Re: X Axis 8mm Brass Nut July 15, 2014 01:17PM |
Re: X Axis 8mm Brass Nut August 09, 2014 07:21PM |
Re: X Axis 8mm Brass Nut August 10, 2014 09:43AM |
Re: X Axis 8mm Brass Nut August 10, 2014 04:11PM |
Re: X Axis 8mm Brass Nut August 10, 2014 06:29PM |
Re: X Axis 8mm Brass Nut August 12, 2014 01:02PM |
Re: X Axis 8mm Brass Nut August 12, 2014 03:48PM |
Re: X Axis 8mm Brass Nut August 16, 2014 03:41PM |
Re: X Axis 8mm Brass Nut August 17, 2014 12:17AM |
