Plywood frame? 300 x 200 bed? October 15, 2014 07:45PM |
Re: Plywood frame? 300 x 200 bed? October 16, 2014 04:40AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Plywood frame? 300 x 200 bed? October 16, 2014 08:15AM |
Re: Plywood frame? 300 x 200 bed? October 16, 2014 12:09PM |
Re: Plywood frame? 300 x 200 bed? October 16, 2014 12:56PM |
gsport
Good point on the X vs Y axis. You are assuming that I would need to widen the spacing of the Y axis bearings as much as the increase in the bed size, whereas I had assumed that I would leave it as it is.
gsport
I could also put a support in the middle of the long bar and space out the linear bearings even more so they effectively all have their own rail at the shortest possible length (300mm + bearing length). I will have to think about this.
gsport
Do you think 8mm would be OK for a X axis at 300mm rather than 200? If I size up to 10mm then the weight of the bars more than doubles, but as this axis doesn't need to move often or fast I think it would be fine.
Re: Plywood frame? 300 x 200 bed? October 16, 2014 03:42PM |
Re: Plywood frame? 300 x 200 bed? October 16, 2014 04:08PM |
Re: Plywood frame? 300 x 200 bed? October 16, 2014 08:12PM |
