My Mendel90 project
Posted by Rich K.
My Mendel90 project
October 26, 2014 09:40PM
Thought I'd post a few pics of my Mendel 90 "Sturdy" as it is thus far. Will post more as things progress. I just assembled the X and Z axes this evening. Adjusted the voltages on my Melzi last night. I'm not going to attach my extruder until the machine is leveled (no point in putting the extruder on if I have to remove it to put my indicator in its place). I'm waiting for my limit switches to arrive from Nophead (hopefuly tomorrow or Tuesday, depending on when they got sent out; it generally takes a week or so for things to arrive here via Royal Mail).
Re: My Mendel90 project
October 27, 2014 10:06AM
Nice report. I am waiting for updates.
October 28, 2014 09:46PM
Ran most of the wiring this evening, and installed the spool brackets (had to open the notches a bit wider with a knife to allow for my 1/2" MDF, which is ~.03" thicker than 12mm. End stops still have not arrived, but I ran the wires for them anyway. My motors have a different color code than the ones Nophead supplies in his kits, and are lower torque, but I am hoping they will still work (maybe at a lower speed). The torque on my motors is still rated higher than the ones originally specified for the Mendel reprap, so I am keeping my fingers crossed.
October 29, 2014 08:57PM
Will be interested to see your prints when you are done building.
Edited 1 time(s). Last edit at 10/29/2014 08:59PM by Garry Bartsch.
November 02, 2014 05:58PM
Well, it is 99% finished. Only problem is, I have to replace my z and extruder motors. In my ignorance, I bought 3 12-volt motors (I had bought the two motors I used in the X and Y axes earlier - they're rated at around 5v). I had wired the X ribbon cable backwards, leading to a great deal of frustration as to figuring out what the problem was. Fixed that, at least. My much-maligned Mk2b heated bed with the through-plated holes WILL get up to the full 110 degrees specified in the "ABS preheat" settings built into my Panelolu2, and the hot-end (a Chinese J-head clone) also heats up nicely. Won't know how well it prints until I replace those three motors, though, and get the bed leveled and the machine calibrated. Might be a couple more weeks, folks... sad smiley
Re: My Mendel90 project - IT'S ALIIIIIVE!!!!!! smileys with beerhot smiley
November 14, 2014 09:02PM
WOOO HOOOO - IT WORKS!!!
Mendel90 video 1
Mendel90 video 2
My first attempt last night was made with bare (cleaned with acetone) glass. Started to work, but then my Melzi shut down - I think I may have had the motor voltage turned up too high. Fixed that problem. Subsequent attempts would not stick to the glass, no matter how clean I got it. Put blue tape on it, and the print came out fine (except that the finished print didn't want to come off the tape...).
Thanks for all the help, Chris, Neil, and all the other forum members who offered help and advice. Chris, you designed a great machine. I know I am happy with it!
November 14, 2014 10:28PM
Great job Rich! Your first android looks awesome. If that is your first print I can say you are going to have a lot of fun with your machine!
Some PLA sticks easily to glass; others doesn't stick well at all. I think the colorant or pigment makes the difference. Natural PLA seems easy to print to bare glass. But make sure you have the first layer hot enough or you won't get it to stick to the glass. If the first layer fails keep bumping up the temperature on subsequent attempts. You should find it starts sticking at some point. The glass needs to be hot enough too. I set mine to 80C which most would say is too hot. But it works. And I don't drop the temperature of the bed through the print.
But now I mostly use this method to apply PVA glue (I use LePage Carpenters glue): PVA Glue Application. I don't seem to have any problem with poor quality PLA sticking. You may like to try this.
I am curious if a Mendel90 with such a solid frame like yours is quieter than one with a Dibond frame? But I know you likely haven't been able to compare. Would you say your machine is quiet?
Good luck!
November 15, 2014 12:22AM
I'd say it's pretty quiet, apart from the normal noise you'd get from the steppers. Watch the videos and it might give you some idea of the noise level. Not much there, really.
November 15, 2014 01:30AM
I'm guessing it sounds similar to my Dibond machine but it's really difficult to compare without hearing directly. I assume vibration would be less possible with a 1/2" wood frame but I'm guessing again.
I'd sure like to see more prints if you ever would be willing to post some.
November 15, 2014 01:35AM
All of a sudden I seem to be having a jamming problem with my PLA. Not sure why, but after that frst print it doesn't want to print worth a darn. Currently trying to figure out why... sad smiley
November 15, 2014 02:01AM
I'm guessing. Are you running the fan after the first layer is done? J-heads need cooling or heat will creep up the hot end body and will cause the filament to soften high up in the cool section and it will jam in the hollow hex screw. You would need to take the hot end out of the Wade's block and remove the jam. I did this. Twice.thumbs down
November 15, 2014 02:16AM
Even with the fan running, my hotend is getting PLA blobbed all over its end rather than laying it down on the build surface. I also think my splined bolt would do better if it was hobbed instead. The splines are getting clogged easily, and I also think it is flattening the filament out.
November 15, 2014 02:33AM
Are you printing to bare glass now? If the extruded filament does not stick to the glass it will glob up on the nozzle. Draw a cylinder 40mm in diameter (circles stick easily) and slice that with your extruder set to 205C and bed to 80C. Speed 25mm/sec. Print that and see if the PLA sticks and doesn't gob onto the nozzle.
November 15, 2014 02:35AM
Yeah, I was trying bare glass. I think I'll go back to blue tape for now - it worked for the 'droid...
November 15, 2014 03:13AM
Things that work are good things smileys with beer
November 16, 2014 07:42PM
I seem to finally be getting the hang of things. I successfully printed a knob for my Panelolu2. As of this moment it is printing up the back panel for the P2. I tried to print the front panel for it as well, but my Slic3r settings were wrong and the fan shut off, causing the hotend to overheat and jam after the second layer. Re-sliced everything and the printer seems to be going smoothly now. Will post photos when this set of prints is done (P2 case)!
November 18, 2014 10:15AM
The thermistor temperature is quite a bit higher than the top of the glass. Setting the temperature at 75C gives me just under 60C on the top. Glass is less forgiving of slight miscalibration than blue tape.
Cleaning glass with window cleaner can make it less sticky. I use vinegar.
November 18, 2014 07:19PM
I use acetone, myself. Evaporates fast with no residue, and gets up any plastic remains. Thanks for the heads-up on temp, have to remember to set the temp for 15 degrees higher for bare glass.
