More spare parts (with pictures) November 05, 2014 05:54AM |
Material: 3dfilaprint White ABS 3mm Print speed: 40mm/s, 20mm/s first layer Layer height: 0.4mm Line width: 0.5mm Infill: 98% - linear Extruder temperature: 220C Heated Bed temperature: 125C (for 110C at glass surface) Build surface: 2mm plain glass with ABS Juice Slicer: skeinforge Special processing: Filament oversized by 0.055mm in skeinforge, all 3 items plated in Slic3r and re-exported as STL for slicing
Re: More spare parts (with pictures) November 05, 2014 06:08AM |
Re: More spare parts (with pictures) November 05, 2014 06:42AM |
Re: More spare parts (with pictures) November 05, 2014 07:47AM |
Re: More spare parts (with pictures) November 05, 2014 08:58AM |
Alzibiff
Reducing the tendency of parts to warp by increasing layer height to 0.4mm - what I suspect is the absolute maximum - is interesting. Any ideas why this is? Anything to do with the reduced time to complete the print I wonder, compared to say 0.2mm?
Alzibiff
The extrusion temperature of 220C for ABS is 25C less than I have used, I assume that you did not get any delamination problems. Have you used similar settings on other parts with similar results?
Re: More spare parts (with pictures) November 06, 2014 01:15PM |
