Curse you Skeinforge! December 25, 2014 10:43AM |
File C:/Users/Tim/Documents/RepRap/Mendel90/Mendel90-master/sturdy/stls/cable_cl ip_AB.stl is being chain exported. Carve procedure took 0 seconds. Preface procedure took 0 seconds. Inset procedure took 1 second. Fill procedure took 1 second. Speed procedure took 0 seconds. Temperature procedure took 0 seconds. Raft procedure took 0 seconds. Chamber procedure took 0 seconds. Jitter procedure took 0 seconds. Clip procedure took 0 seconds. Cool procedure took 0 seconds. Limit procedure took 0 seconds. Alteration procedure took 0 seconds. Exception in Tkinter callback Traceback (most recent call last): File "C:\Python27\lib\lib-tk\Tkinter.py", line 1532, in __call__ return self.func(*args) File "C:\Users\Tim\Documents\RepRap\Skeinforge_Nophead\Skeinforge50plus-master \fabmetheus_utilities\settings.py", line 1173, in execute self.repository.execute() File "C:\Users\Tim\Documents\RepRap\Skeinforge_Nophead\Skeinforge50plus-master \skeinforge_application\skeinforge.py", line 592, in execute skeinforge_craft.writeOutput(fileName) File "C:\Users\Tim\Documents\RepRap\Skeinforge_Nophead\Skeinforge50plus-master \skeinforge_application\skeinforge_utilities\skeinforge_craft.py", line 135, in writeOutput return pluginModule.writeOutput(fileName, shouldAnalyze) File "C:\Users\Tim\Documents\RepRap\Skeinforge_Nophead\Skeinforge50plus-master \skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 291, i n writeOutput exportGcode = getCraftedTextFromText(gcodeText, repository) File "C:\Users\Tim\Documents\RepRap\Skeinforge_Nophead\Skeinforge50plus-master \skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 136, i n getCraftedTextFromText return ExportSkein().getCraftedGcode(repository, gcodeText) File "C:\Users\Tim\Documents\RepRap\Skeinforge_Nophead\Skeinforge50plus-master \skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 383, i n getCraftedGcode self.parseLine(line) File "C:\Users\Tim\Documents\RepRap\Skeinforge_Nophead\Skeinforge50plus-master \skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 418, i n parseLine line = self.getLineWithTruncatedNumber('Z', line, splitLine) File "C:\Users\Tim\Documents\RepRap\Skeinforge_Nophead\Skeinforge50plus-master \skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 391, i n getLineWithTruncatedNumber roundedNumberString = euclidean.getRoundedToPlacesString(self.decimalPlacesE xported, float(numberString)) ValueError: could not convert string to float: [first_layer_height]
Re: Curse you Skeinforge! December 25, 2014 11:34AM |
G1 Z[first_layer_height] ; move nozzle to print height
G1 Z0.35 ; move nozzle to print height
Re: Curse you Skeinforge! December 26, 2014 12:31PM |
M140 S[first_layer_bed_temperature] ; set bed temp and don't wait G28 ; home all axes(I home Z to the top, which is slow on my machine, so I like to start the bed heating whilst it is homing)
M140 S70 ; set bed temp and don't wait G28 ; home all axes
M140 S< setting.chamber.BedTemperature >
M109 S< setting.temperature.BaseTemperature > ; set extruder temp and wait
Re: Curse you Skeinforge! December 27, 2014 03:37PM |
Re: Curse you Skeinforge! December 27, 2014 04:24PM |
dawa
I wonder if it is possible to prevent skeinforge from saving the settings for every click you perform in the GUI.
To counter that behaviour I have a backup file tree, and remove/overwrite the working tree regularly, replacing it with the backup tree, to "undo the autosave".
