Acrylic BOM
Posted by yiancar
Acrylic BOM
March 10, 2015 07:29PM
Hello everyone,
I am clearly new to this so please bare with mesmiling smiley
I was looking at the BOM of mendel compared to dibond and i notticed that it has not square steel pillars on the bottom even tho the frame holes are there.
Should I use them on an acrylic design?
also is there any benefit of using t2.5 belt instead of t5 and the corresponding pulley instead of the printed one?
Thank you,
Yiangos
Re: Acrylic BOM
March 11, 2015 11:13AM
It doesn't have the holes for them at the front. The holes at the back are shared with the fixing blocks on the Dibond version and for the fixing blocks only on the acrylic.
They are only required on the Dibond version because it has screw heads underneath, so has to be lifted up. The acrylic has tapped holes and a thicker base so it doesn't need the tubes, which are actually aluminium not steel.
I don't think there is much difference between well printed T5 pulleys and T2.5 but printed ones can be hit and miss and T2.5 are more readily available nowadays, so I would recommend those or GT2. You can select either and rebuild the files to get plastic parts to match.
Re: Acrylic BOM
March 11, 2015 05:58PM
Thank you for the help. I am trying t generate the files but i get
Traceback (most recent call last):
File "/Users/yiangosyiangou/Documents/Mendel90/make_machine.py", line 17, in
make_machine(sys.argv[1])
File "/Users/yiangosyiangou/Documents/Mendel90/make_machine.py", line 10, in make_machine
boms(machine)
File "/Users/yiangosyiangou/Documents/Mendel90/bom.py", line 119, in boms
f = open("scad/conf/machine.scad","wt")
IOError: [Errno 2] No such file or directory: 'scad/conf/machine.scad'
any idea?
thank you,
Yiangos
EDIT: if you have a mac: Use Search
Edited 1 time(s). Last edit at 03/11/2015 07:01PM by yiancar.
Re: Acrylic BOM
March 11, 2015 07:04PM
That is a mystery because that line is opening the file to write to it, so it should not matter if it exists. Also the file does exist on github [github.com], so it is a double mystery.
Do you have a /Users/yiangosyiangou/Documents/Mendel90/scad/conf directory?
Re: Acrylic BOM
March 11, 2015 10:25PM
Someone found the solution, Mac i would say... i edited the link above.
Thank you for the helpsmiling smiley
