Mendel90 Auto Bed Leveling
Posted by D4RK1
Re: Mendel90 Auto Bed Leveling
April 01, 2015 01:12PM
It works a bit but not as it well as it could do due to only taking the height information from the last point probed. It treats the probe as a limit switch so each hit is like homing.
Also there have been a few maths errors that I pointed out so it depends when you download it. Also if you downloaded in the last few days it is likely to several mm out and your heaters might turn immediately!
April 01, 2015 03:58PM
nophead
This is actually quite damaging for Marlin. I cannot understand the logic behind embarking on a major restructuring of the project without having some means of backporting bugfixes to a known stable reference point.
Users cannot take code from the new repository and expect it to function reliably on their printer.
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
April 02, 2015 09:24AM
The branch ist called development. So nobody can expect to get a rock stable version.
There are also two releases, 1.0.1 and 1.0.2. that can be choosen and used.
At least the 1.0.2 was fine for me on the Mendel90 for a very long time. Some graphical unattractiveness.
But the printing was fine.
It was only boredom why I start using the development branch. Not the last one sure.
But some weeks before. There was no issue with the heaters and also ABL is working fine.
