Has anyone used this controller April 29, 2015 09:53PM |
Re: Has anyone used this controller April 30, 2015 08:55AM |
Re: Has anyone used this controller April 30, 2015 08:38PM |
Re: Has anyone used this controller May 01, 2015 04:50AM |
Re: Has anyone used this controller May 01, 2015 09:20AM |
Do you have your serial port set? Correct board type (use the Mega 2560 option)?Quote
stilgarhammer
On the firmware, the seller sent me a copy of the Repetier software. I also have the display unit connected to the board. when I connect board to my pc, it goes through the compile but then soon after during upload I get a error stating its not responding. Do I need to connect the 12 power unit to board also, and not power the board only with USB cable?
Pins 1-2 and 3-4 would be the default pairing. Check your motor specs to see which wires are pairs and wire them up as such. If the motor runs backwards, adjust your firmware or flip the wires.Quote
for the hookup diagram,
I need the pinout for the stepper drivers (what pin is A1, B1 and so on).
You'd use the signal and ground pins on the board.Quote
for the end stops, my switches are connected with com to gnd, and the NC to signal, what conector I use?
Yes.Quote
The Z axis is at the top, would that be connected to the Z+ connector?
Re: Has anyone used this controller May 01, 2015 03:32PM |
