I should add here that my fork is not currently using the latest code. There has been heavy development on Marlin recently which has led to some breakage at times.
I have decided to hold updates to my firmware until I can be sure that the mainstream Marlin is stable. As cdru mentioned Z probing works satisfactorily.
For a sturdy you might need to adjust some of the mechanical settings. I based mine on the Dibond kit variant and obviously things like thermistor tables may be different if you have used alternative devices.
I recently adjusted to core files usage which means that it will now compile under Arduino 1.5 or later but I am not sure if there are some issues with the code and the later versions of GCC used with them. I recommend that you use Arduino 1.0.6 to build my firmware.
Regards,
Neil Darlow
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
