Leveling
Posted by yiancar
Leveling
May 25, 2015 12:15AM
I have build my plexiglass mendel90 and its impossible to level, the heat bed pcb is a bit curvy but the glass sheet is straight( or it seems).
i can make the corners at the same hight but when i recheck the centre, its not. Is there a chance that my glass sheet is uneven or that the clips are causing tension on the glass?
Thanks
Yiangos
Re: Leveling
May 25, 2015 04:30AM
If you are testing it with a dial gauge then it will bend the middle downwards.
Re: Leveling
May 25, 2015 08:34PM
Which means that as long ad the corners are leveled I am ok?
Re: Leveling
May 26, 2015 06:33AM
Yes the corners are supported by the posts but in between the spring of a dial gauge will deflect it slightly.
