Help. Y shift halfway through a print. [SOLVED] May 28, 2015 03:11PM |
Re: Help. Y shift halfway through a print. May 28, 2015 08:14PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Help. Y shift halfway through a print. May 28, 2015 09:54PM |
nophead
Is it 1mm or 0.8mm?
The former is hard to explain but the latter is a skipped motor step. A skipped motor step means not enough torque for the acceleration. I.e. increase the motor current or reduce the acceleration. Or it can be caused by too much friction if the bearings have seized.
Re: Help. Y shift halfway through a print. May 29, 2015 04:16AM |
Re: Help. Y shift halfway through a print. May 29, 2015 05:55AM |
Re: Help. Y shift halfway through a print. [SOLVED] May 29, 2015 08:37AM |
