Extruder problems June 01, 2015 08:48AM |
Re: Extruder problems June 01, 2015 11:14AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Extruder problems June 01, 2015 01:50PM |
Re: Extruder problems June 01, 2015 04:14PM |
Re: Extruder problems June 01, 2015 04:52PM |
Re: Extruder problems June 01, 2015 07:33PM |
Re: Extruder problems June 02, 2015 05:37AM |
Re: Extruder problems June 02, 2015 09:32AM |
Re: Extruder problems June 02, 2015 04:48PM |
Re: Extruder problems June 02, 2015 05:19PM |
Re: Extruder problems June 02, 2015 05:33PM |
Re: Extruder problems June 02, 2015 08:01PM |
Re: Extruder problems June 03, 2015 05:18AM |
Re: Extruder problems June 03, 2015 06:16AM |
Re: Extruder problems June 03, 2015 12:36PM |
neildarlow
@yiancar The simplest solution is to use the recommended diameter filament.
I recently worked with someone who switched a Prusa i3 from a direct drive to Bowden extruder and he had so many problems he was forced to revert. The cost of buying new filament is less than the time wasted in correcting such an occurence.
Regards,
Neil Darlow
Re: Extruder problems June 13, 2015 05:53AM |
Re: Extruder problems June 13, 2015 04:31PM |
Re: Extruder problems June 13, 2015 05:11PM |
Re: Extruder problems June 14, 2015 11:26AM |
I changed the scad to work with 1.75 mm filament.Quote
nophead
If you are using the standard Mendel90 extruder it only works with 3mm filament.
I replaced the original 11:39 gears with 23:27 to compensate for the lower speed.Quote
nophead
It might work or it might not close far enough, depending on the hobbed bolt. However you don't want a geared extruder for 1.75mm filament as you want to drive it 3 times faster with 1/3 of the force. Having it geared will limit your retract speed.
Re: Extruder problems June 16, 2015 05:13PM |
