Startcode in Simplify3d won´t work July 12, 2015 04:31AM |
Re: Startcode in Simplify3d won´t work July 12, 2015 05:58AM |
Re: Startcode in Simplify3d won´t work July 12, 2015 06:04AM |
Re: Startcode in Simplify3d won´t work July 13, 2015 03:53AM |
; ***** Ooze-free unattended start with wipe, front edge (LEDs ON) ***** G90 ; Set positioning to absolute G21 ; Set units to millimeters (if required?) G28 ; Home all axes G92 E0 ; Reset extruder M42 S255 P28 ; Turn on the gantry LEDs on FET 1 G1 Z200 X-45 Y95 F12000 ; Move above block point M190 S[first_layer_bed_temperature] ; Pre-heat the bed & wait as it takes longer M117 Remove insulation! M104 S[first_layer_temperature] ; Start heating the extruder before lowering the nozzle G1 Z0.1 X-45 Y95 F12000 ; Lower to block point and block nozzle M109 S[first_layer_temperature] ; Wait for extruder to reach first layer temperature G4 S120 ; Wait another 120 seconds for nozzle length to stabilise G1 E3 ; Extrude 3 mm of filament G1 X45 Y95 F12000 ; Wipe nozzle across the bed G1 Z1 ; Raise nozzle to 1 mm ready to begin main sequence G92 E0 ; Reset extruder M201 X2000 Y2000 ; max acceleration in X and Y M117 Printing...
