Clog hot head - up high
Posted by sharonf88
October 18, 2015 11:34AM
Hi fellas,
My hot head got clogged, I disassembled it and realized its blocked up-high where the filament enters the heating element.
Any tips on how to remove it? I tried heating to 230 but the heat is not reaching up there to make it rubbery enough to insert some tool and pull or clean.
Should I drill it?
[postimg.org]
Thanks!
Edited 1 time(s). Last edit at 10/18/2015 11:34AM by sharonf88.
Re: Clog hot head - up high
October 18, 2015 02:05PM
No don't drill it. Dip the top in a glass of hot water to make the blob rubbery, then pull it out with needle nosed pliers.
October 19, 2015 05:52AM
Hot water wasn't enough.I eventually used a mini-torch with a hot head to melt and distort the lump of plastic that was blocking + needle nosed pliers.
October 19, 2015 07:57AM
I should have said hot water from a kettle. It only needs to heat the PLA to 60-70C but hot water from a tap is probably not that hot.
