mendel90 CNC mill
October 25, 2015 04:49AM
hello,
i don't use m mendel 90 anymore for 3D printing so i want to use him now as a CNC mill for PCB milling.
i've already mount a dremel and a milling surface instead of the heatedbed but know i need a firmware update, is there already a firmware?
regards
Re: mendel90 CNC mill
October 25, 2015 06:47AM
I believe that GRBL is designed for CNC milling. You could start with that.
Regards,
Neil Darlow
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
October 27, 2015 02:36AM
Hi 3Design,
How did you mount your Dremel. I'm trying to build somehting simular for my father in law.
Thanks in advance.
regards,
Paul
October 30, 2015 06:53PM
I'm also interested in a CNC mod....
October 31, 2015 04:55PM
I will use a flex shaft with my dremel. If that doesnt work well, i will make me a new x carriage where i can mount my dremel on.
October 31, 2015 08:31PM
The problem with flex shafts is they all seem to have end play. Perhaps another bearing can be added to prevent it.
Something like this might be better: [www.thingiverse.com]. Lighter, faster and also can vacuum up the chips.
November 01, 2015 02:42AM
There are a lot of people that uses a dremel tool and the results are good, i will give it a try
But that piece from your link looks great and i will print that out just for checking because it looks very handy
November 01, 2015 04:43AM
3Design
...i don't use m mendel 90 anymore for 3D printing ...
followed by
3Design
... i will print that out just for checking because it looks very handy
spinning smiley sticking its tongue out
Think you need another M90 kit or have you already got another 3D printer?
Alan
Edited 1 time(s). Last edit at 11/01/2015 04:44AM by Alzibiff.
November 01, 2015 06:39AM
i ve a k8400 vertex that i use now for printing
