Fan not working all of the sudden
December 04, 2015 05:45AM
Hi guys!
The other day I sent a print and came back to see a mess. Printing another file made it clear that the problem was the fan was not turning on (I'm printing ABS).
What I've tried:
- M106 / 107 on pronterface : Fan not turning on
- Setting fan to work all the time while printing on slic3r : No result
- Changing to another fan : No result
Could someone perhaps guide me using a multi-meter to find out where the problem is?
Everything else (motors and heaters) are working fine.
Thanks!
Re: Fan not working all of the sudden
December 04, 2015 08:52AM
I never use a fan when printing ABS, not sure why you would get a mess, but it would be more likely to warp and de-laminate with a fan.
Check the voltage at the fan connector on the Melzi. There should be 12V across the two terminals when the fan is on.
December 04, 2015 01:20PM
Also check continuity between the fan- pin on the Melzi and the black lead of the fan and between fan+ and the red lead. There isn't actually a wire in fan+ because it shares the connection with the heater.
December 06, 2015 05:49AM
Hi Chris,
The reading at the fan connector on the Melzi is 11.7-11.8V
December 06, 2015 08:38AM
Looks like a wiring fault then. Could be the at the Melzi terminal, the IDC connector or the soldering on the extruder PCB.
