Anonymous User
direct drive extruder on the repository
January 12, 2017 08:30PM
I've been using my trusty sturdy mendel90 since 2013. 3mm filaments/extruder.
I'd really like to use the direct drive extruder Chris (nophead) added to the
mendel90 repository, but I'm having trouble compiling/exporting the individual .stl files.
Anyone managed to do this?
Thanks!
Edited 2 time(s). Last edit at 01/12/2017 09:09PM by 111oct111.
Anonymous User
Re: direct drive extruder on the repository
January 13, 2017 09:54AM
The direct.scad file contains the extruder, with a jhead by default. I need it with a mk8 hobbed gear and e3d block. I tried reconfiguring the machine and running the compiling scripts, but I can only get the standard wade extruder, just cant export the direct files for printing. What am I missing?
Help?
January 13, 2017 12:12PM
You have to change the extruder type in the dibond_config file to Direct17
hot_end = e3dv6;
extruder = Direct17;
To export single stl files you can do
stls dibond direct_extruder.stl
stls dibond direct_idler_lever.stl
Anonymous User
January 13, 2017 01:35PM
Thank you so much Chris. You´re a legend!
January 01, 2018 03:29PM
How do I generate an assembled / exploded view of the direct drive extruder and hot end?
There's a couple of images on the blog post (http://hydraraptor.blogspot.com/2016/01/mendel90-github-catch-up.html) but I'm still trying to make sense of how it all goes together.
Edited 1 time(s). Last edit at 01/01/2018 04:12PM by jswilson64.
