Idea for stopping the flexing in a mendel90 May 13, 2017 07:04AM |
Re: Idea for stopping the flexing in a mendel90 May 16, 2017 03:55PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Idea for stopping the flexing in a mendel90 May 16, 2017 04:06PM |
nophead
All you need to do to prevent it wobbling is to place it on a firm flat surface. I have never seen the corners lift while it is printing.
Re: Idea for stopping the flexing in a mendel90 May 17, 2017 12:04PM |
Re: Idea for stopping the flexing in a mendel90 May 17, 2017 02:57PM |
ah. apologies but it's been over 18 months now, and i knew less then than i do now so wasn't specifically looking for that as a symptom. what i *did* notice was that the cardboard on which the printer sat, on a high (polished) table, would actually move about! the table's legs were clearly undergoing vibration.Quote
nophead
Are you saying the corners of the base lift if you print at 250mm/sec?
I am confused by what you mean by "instead of the known problematic bowden concept" because Mendel90 doesn't use Bowden drive to feed the filament.
Yes you can use a Flex3drive to make the X carriage lighter but the Y carriage is the heaviest axis.
Re: Idea for stopping the flexing in a mendel90 May 18, 2017 07:20AM |
Re: Idea for stopping the flexing in a mendel90 May 22, 2017 10:00PM |
Re: Idea for stopping the flexing in a mendel90 May 24, 2017 04:22AM |
Re: Idea for stopping the flexing in a mendel90 May 24, 2017 09:49PM |
